Author Topic: something loose behind dash when cornering  (Read 3628 times)
kayemoxon
« on: March 05, 2011, 17:46:08 »
Help please...
I dont know whether this is the correct forun for my question? Car is a 250SL 1967
When cornering, something sounds as it it is loose and slides with a clonk against the door side of the dash. It happens when turning (under speed) left or right and the clonk is sounding against both sides . In other words, something(s) is/are  shifting under the mild G force. The noise is not terribly loud but is irritating.
Any ideas?
Ms Kaye Moxon (Cardiff UK)
rmmchl
  • USA, WV, Charleston
Re: something loose behind dash when cornering
« Reply #1 on: March 05, 2011, 21:17:29 »
i hope it's not the tack welds on the heater core.
michael romeo
1967  250sl
signal red
« Reply #2 on: March 05, 2011, 23:49:11 »
The brace that runs along the inside bottom of the dash board has a U shaped channel along the top, small parts like the thumb nuts that hold the instruments can get dropped into this channel and lost (when work behind the dash is being done) then roll around making noises when cornering.
I'd suggest removing the glove box and check this channel (it follows the line of the lower dash pad but behind the dash board) for odd bits that have been left behind from previous work.
kayemoxon
« Reply #3 on: March 06, 2011, 00:17:56 »
Thanks for the replies
I dread taking down the dash to check the heater core nut I will take out the glove box tomorrow and take a look around. I think the noise is 'heavier' than that which might be caused by smaller components like thumbnuts etc. It sounds a bit like a slide hammer!
rmmchl
« Reply #4 on: March 06, 2011, 03:51:45 »
let us know on this site what it was ------------------i think it has something to do with the heater box or core
michael romeo
1967  250sl
signal red
