Author Topic: Transmission Fluid Change Question  (Read 3023 times)
Travis71280
« on: March 14, 2011, 15:22:18 »
Hi all, I was going to change the transmission gasket (automatic) in the car since its been leaking. I want to say theres a crush washer that seals the dipstick to the transmission pan. Is it necessary to get a new one or should it be fine if I reuse it? Thanks again in advance.
Re: Transmission Fluid Change Question
« Reply #1 on: March 14, 2011, 23:03:50 »
Most pan gasket kits come with the sealing washers unless you buy the gasket only.
