Author Topic: Heater Blower Motor Upgrade  (Read 6723 times)
shanghaitom
« on: March 21, 2011, 19:45:12 »
I am restoring a 1970 280SL and have completely disassembled the heating unit.  As many have commented, the airflow from the Behr blower is lacking.  I work at SPAL, an Italian maker of fans and blowers, and asked our tech department to see what they could do.  Because we don't offer a blower motor as a bolt-in replacement, the tech wizards took a blower motor (model A45) from a standard SPAL blower, and retrofitted it into the Behr unit.  It required drilling holes in the motor housing for the two horizontal bolts that hold it in place and affixing a 3 speed resistor to reduce current draw for the car's existing electrical system.
The resistor is 3 speeds, but only low and medium are hooked up, which seems to offer plenty of airflow over the standard.  However, I have yet to install it in the vehicle.  Attached are a couple pictures of the before and after.  You will see that the resistor is placed near the blower wheel to offer adequate airflow.
Hope you find it interesting!
Cheers,
Re: Heater Blower Motor Upgrade
« Reply #1 on: March 22, 2011, 14:01:50 »
Nice work
When do you start taking orders on these units? ;)
shanghaitom
« Reply #2 on: March 22, 2011, 14:22:56 »
If anyone has interest, I'd be happy to pass along the contact info for the guy that actually did the work!
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #3 on: April 03, 2011, 02:05:01 »
Tom,
I bought a SPAL Type 017-A40-22 to replace the air conditioner blower in the car.  I was wondering what to do to improve the heater blower.  Just today, I pulled the blower and heater core out.  What would be an approximate cost to make a kit with all the parts one would need?
