Author Topic: Fuel distributor oil feed question  (Read 3946 times)
230SL
« on: March 25, 2011, 03:25:31 »
The car is a 1966 230sl i removed the oil feed line which attaches from the engine block (below the rpm cable input) and the fuel distributor (right side of pump next to fuel line) I removed it to paint it and stupid me never checked to see which screw went where.  One bolt has some kind of restriction(small hole) and one hole in the bolt since its a banjo bolt.  The other bolt has no insert to restrict and 3 holes for the feed.
Which bolt goes where????
Also while i am on the topic just to make sure no one else touched it the engine block side has aluminum washers and the fuel distributor has copper washers is that right?
230SL
Re: Fuel distributor oil feed question
« Reply #1 on: March 26, 2011, 00:42:35 »
Yikes i guess I made a big mistake removing it, figured it might have happen to someone else
« Reply #2 on: March 26, 2011, 02:22:56 »
The unrestricted hole goes in the block.
230SL
« Reply #3 on: March 26, 2011, 15:47:47 »
Figured that eneded up putting the line the other day only made sense to me that way thank you for the response
