Author Topic: Spark Plug Gap?  (Read 6254 times)
Jordan
  • Canada, ON, Jordan
Spark Plug Gap?
« on: March 27, 2011, 18:58:54 »
I have searched the site on spark plug gap and the concensus seems to vary from 0.7mm (0.028in) to 0.035in.  I was unable to find anything in the BBB, although my eyes were glazing over by the time I reached the end of the book.  Both the Veloce and Haynes workshop manuals for the 230SL list a 0.5mm (0.020in) spark plug gap.  ???  I have not seen anything this low specified on this site.  I am going to install Bosch VR9DC+ plugs and I have a 051 distributor in a late model 230SL.  What is the correct spark plug gap.  The new plugs currently have a 0.028in gap.  Many thanks.
Marcus
66 230SL  Euro 4 speed
Re: Spark Plug Gap?
« Reply #1 on: March 27, 2011, 21:48:32 »
Jordan, .031 sounds about right--between the .028 and .035 for stock setup.  Never heard of .020 sounds a bit tight to me.  I'll have to check my own Haynes on that one!
If you have an electronic ignition and higher voltage coil, you can open up the gap a bit since the spark is larger.  I'm running about .035+ on NGK BP6ES with Pertronix--but I have their Ignitor II high voltage coil.
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: Spark Plug Gap?
« Reply #2 on: March 28, 2011, 00:48:58 »
I have been setting mine at .035.  I also just bought some original Bosch W7DC plugs for the next time I change them.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
W113SL
Re: Spark Plug Gap?
« Reply #3 on: March 28, 2011, 12:26:30 »
Brad:  Good move, the original W7Dc are hard to find.  In my experience , the engines especially the earlier non transistorized ignition ones, run better with these original copper core plugs.  I've tried the WR7 and WR9's but when the engine is tuned correctly, i.e. not too rich at idle, the W7's are best in my view.
Pete Lesler
largely original
