Author Topic: Where to measure head?  (Read 5999 times)
Eminent
« on: March 31, 2011, 09:35:53 »
Hello.
Soon the head will go off. I'm curious if the head is decked before.
Can anyone tell me where to measure the head?
And what the size is of an undecked head.
It's a 130.980 engine.
Thanks for any input.
Rini.
Re: Where to measure head?
« Reply #1 on: March 31, 2011, 13:03:26 »
Hello Rini,
The stock head is a uniform thickness of 85mm.   Minimum thickness is 84mm.  Measure the head at three or four locations along its lenght for thickness. Typically the front and back end of the head will be where the most material is removed when the head is warped and then "cut".
Use a good accurate caliper or micrometer to measure thickness. Make sure all measurement surfaces are good and clean.
Eminent
« Reply #2 on: March 31, 2011, 20:20:13 »
Thanks for you answer. I'm curious if it's decked before.
Is it correct that there are thicker gaskets for heads that are cut a few times?
« Reply #3 on: March 31, 2011, 21:42:03 »
Hello Eminent,
I have heard of these thicker gaskets for other makes of cars, but have never heard of them for Mercedes.
Eminent
« Reply #4 on: March 31, 2011, 22:12:15 »
Ok.
I thought so because this partnumber, A1300165520, is a head gasket and in Mercedes EPC there is the following note with that gasket "standard and up to repair size 1".
A1300165620 also a head gasket with the note "repair size 2".
Don't know what they mean by that.
Anyhow, thanks for your answers.
« Reply #5 on: April 01, 2011, 02:29:55 »
Interesting, it may be worth a call to The Classic Center to find out.
Eminent
« Reply #6 on: April 01, 2011, 07:16:20 »
Well. I think i'm often at the dealer to order parts the next few weeks. See if they know what that means. You'll hear from me.
jacovdw
« Reply #7 on: April 01, 2011, 08:50:31 »
...A1300165520, is a head gasket and in Mercedes EPC there is the following note with that gasket "standard and up to repair size 1"...
Hello Rini,
The different head gaskets that you have found on the EPC refer not to the thickness of the gasket, but rather to the diameter of the piston.
In other words, if you had the engine rebored the accommodate the next repair size piston, then you would use the appropriate head gasket to match.
As far as I know, Mercedes does not have different thickness gaskets to accommodate an over-milled head.
Eminent
« Reply #8 on: April 01, 2011, 11:01:58 »
Hey Jaco.
Ofcourse, that is what they mean by that note.
I should have think further... ::)
Thanks for clearing things up.
« Last Edit: April 01, 2011, 20:55:35 by Eminent »
