Author Topic: Brown ground wire on Tach.  (Read 3469 times)
paults1
  • USA, FL, The Villages
« on: April 13, 2011, 01:47:13 »
Would there be sufficent ground if I installed the ground wire on the back of the Tach. housing instead of under the 'C' bracket krunled knob.   I can use a nut to secure the wire on the back of the housing on the same threaded piece that secures 'C' the bracket.  This would enable an easier installtion of the Tach.
Paul
Larry & Norma
Re: Brown ground wire on Tach.
« Reply #1 on: April 13, 2011, 07:56:52 »
Should be fine, just check for continuity between the old and new connection points with an ohmeter.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
