I was suddenly confronted with a "mystery leak" - a puddle of oil on the ground, right underneath the steering box. I remember last year checking the oil level, and "topping it up", and now I'm wondering if I over-filled it. I'm not sure why it suddenly decided to drain out now, as it was fine last summer.
1. I remember reading that the level is supposed to be 1.5 inches "below the filler neck" - does that mean 1.5" below the top surface, OR below the bottom of the threads? The threads are about .5" deep.
2. It still shows a level of 1" below the top surface, so it is over-filled either way. Does this mean a seal has to be replaced, or is it just a matter of reducing the oil level?
Will W14
1965 230SL 4spd
Victoria,BC
