Author Topic: Bras & Spark Plugs& Turn Signal  (Read 5966 times)
« on: May 10, 2004, 09:37:53 »
I realize this might be heresy, but I need a bra for my '69 280SL to protect the car from highway driving...I plan on a few trips this year and it will be driven to at least one concours, maybe 2.  Had not too much luck finding a bra on the internet.  Anyone have any ideas?  It will ONLY be used for highway driving to protect the paint and the chrome--too much invested NOT to have one.
Also, when changing plugs yesterday, I noticed that my #1 plug wire had an "L" shaped connector with 5K resistance, and the rest were straight with 1K resistance.  Is this normal?  It was a new Bosch wire set that the restorer put on...
Anyone have a wiring diagram to verify the connections to the turn signal indicator?  I think some wires are reversed somewhere, my headlight "flasher" seems to turn on the washer motor pump.
Mike Salemi
Re: Bras & Spark Plugs& Turn Signal
« Reply #1 on: May 10, 2004, 18:03:38 »
Mike,
All the plug ends should have the same resistance.
isofast
« Reply #2 on: May 10, 2004, 18:13:55 »
1000 ohm wire is correct 5000 is not! Straight at plug end and 90 degree at distributor end. Bigbabbo (Robert) sell's a set of correct Beru wires. The ones he sells on e-bay are Bosch and you will get one incorrect wire in this Bosch set. (angled at number 1 plug end.) If you call and ask he will sell a correct Beru set. I am just a very satisfied customer. E-mail me and I will e-mail you back a colored wire schematic.
Ernie... surffing@comcast.net
I love low mile Mercedes.
1969 280 4spd Papyrus White
graphic66
« Reply #3 on: May 10, 2004, 19:07:57 »
Bosch for some reason sells that set for the 113. It is wrong, I believe the 1 angled plug is to clear parts on a carburated engine. Don't buy those Bosch sets, They are wrong. Sounds like The Beru wires are the way to go. My car had bad wires and I went to a motercycle shop and purchased copper plug wire and screwed my stock ends on and it works great.
  • USA, VA, Alexandria
« Reply #4 on: May 10, 2004, 19:37:30 »
Michael,
If you use a bra, I would suggest an extra heavy wax underneath to protect from grit and dirt that can find its way between the bra and the paint, causing scratches.
