Author Topic: Fuel Gauge Stuck at 1/4 Tank  (Read 4578 times)
mfriedman
« on: May 01, 2011, 16:33:19 »
On my 1965 230SL, the fuel guage operates from off (empty) to 1/4 tank even though there is a full tank of fuel and has a brand new fuel sending unit. Any comments would be appreciated.
« Last Edit: May 13, 2011, 21:58:30 by 280SL71 »
Re: Fuel Guage Stuck at 1/4 Tank
« Reply #1 on: May 02, 2011, 06:18:10 »
There are early and late style sending units which will not interchange unless the fuel gauge is changed also.  Did you install a cylindrical unit or a "lever and float" type?
mfriedman
« Reply #2 on: May 02, 2011, 18:31:15 »
I installed the round aluminum newer type.
« Reply #3 on: May 05, 2011, 15:10:47 »
There is a shipping pin that holds the float in place that needs to be removed before installation of the new sensor.
pablo_o2
  • Belgium, Flanders, Zoersel
« Reply #4 on: May 13, 2011, 17:24:50 »
did you try to change the wiring I noticed when I was experimenting with the wires somehow when they were switched from place the gauge only went to 1/4. Also I read in the technical pages that gauge and sender unit are not interchangeable with newer types. If you changed to the newer tube unit maybe that can cause a conflict also.
