Author Topic: ceramic ballast resister ohm's  (Read 4790 times)
rmmchl
  • USA, WV, Charleston
« on: May 04, 2011, 00:41:34 »
I have a mid 1967 250sl. the tension rod broke my ceramic ballast resister. they make 3 ohm types-------.4---.6---.9 ohm's--My broken one had a silver bracket , but I could have had the wrong one on my car.. My new one from Bud's just came in the mail today. Their mechanic thought it should be a .9ohm. gold bracket. I am just making sure. Can anyone verify the correct one for my vehicle????   Would it cause any harm using a different one?
michael romeo
1967  250sl
signal red
DaveB
Re: ceramic ballast resister ohm's
« Reply #1 on: May 04, 2011, 01:23:04 »
yes pretty sure that's the one if you have the standard black coil
DaveB
'65 US 230sl 4-speed, DB190
rmmchl
« Reply #2 on: May 04, 2011, 02:09:39 »
I do have the standard black coil-Does anyone know the function of the ceramic resisrer?
michael romeo
1967  250sl
signal red
DaveB
« Reply #3 on: May 04, 2011, 05:23:36 »
It protects the coil by reducing current flow to the coil at low revs.
DaveB
jacovdw
« Reply #4 on: May 04, 2011, 08:17:30 »
...their mechanic thought it should be a .9ohm gold bracket. I am just making sure. Can anyone verify the correct one for my vehicle????
If you are using the original black coil then the 0.9 Ohm ballast resistor is correct for your car.
The 0.4 and 0.6 Ohm ballast resistors are used on the transistorized ignition setup of the US spec 280SL's only.
