Author Topic: hard to start after fill up of gas.....  (Read 4391 times)
erickmarciano
  • Canada, Quebec, montreal
« on: May 04, 2011, 21:44:32 »
Hi Guys the cars runs great except when the tank is full.
actually it runs great until I stop for like 10 min than it is hard to start only with full tank. I tried starting it with the gas tank off and still not good.My car a Euro 280sl with the simple fuel susytem with only the little black box on the right rear fender.
Can this be flower pot related?
Erick Marciano
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: hard to start after fill up of gas.....
« Reply #1 on: May 05, 2011, 11:45:14 »
Just a wild guess, thinking out of the box...
If the tank is full, there is a lot of pressure on the return line in the flower pot...so, if there is any obstruction (say, 40+ years of crud) or a weak pump, this pressure might be inhibiting fuel flow?  Just a guess here.
amg65ri
« Reply #2 on: May 05, 2011, 12:22:47 »
I was thinking the same thing, also the top vent may be restricted as well. This coupled with a full tank would complicate matters. As for the flower pot, I could not believe how much build up can accumulate in the tank.... it worth a check, however a full tank is a lot of fuel to catch in a pan before you drop the filter.... :)
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
« Reply #3 on: May 06, 2011, 20:53:54 »
Related question...Is a gas smell common after fill up?
- 2024 Mercedes GLE 350
- 2024 AMG C43 Sedan
« Reply #4 on: May 07, 2011, 14:14:50 »
Where is this gas smell?
You have several vent lines from the tank.  There are clamps and hoses and lines, leading to the canister in the trunk.  If the integrity of any of this isn't 100% you'll smell some gas vapors.
Larry & Norma
« Reply #5 on: May 07, 2011, 16:15:24 »
I agree with Michael, I replaced all hoses and clamps to the canister and all fuel smells went away. Even though visually all appeared to be ok.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
« Reply #6 on: May 09, 2011, 01:54:22 »
I have a slight smell in the trunk when I open the lid. Interesting...I had the tank repaired as part of the restoration. Sounds like hoses and clamps?
