Author Topic: Do all 220SE brake shoes fit 230SL?  (Read 4305 times)
seattle_Jerry
« on: May 11, 2011, 00:08:15 »
I found a 60 220SE that is being parted out locally...the part number on the shoes is 1804230608 which is different than the SL's but they sure look the same.
« Last Edit: May 11, 2011, 00:09:56 by seattle_Jerry »
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: Do all 220SE brake shoes fit 230SL?
« Reply #1 on: May 11, 2011, 02:31:47 »
Check with Tom at the classic center.  I think they will only work if the car has disc brakes in the front.  The ones with front drums have different shoes in back.  So 1963 or newer finbacks would be ok.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
scoot
  • USA, CA, Altadena
« Reply #2 on: May 11, 2011, 15:27:29 »
More generally, are drums, shoes, and other brake parts from fintails that fit the 230 SL in high demand, expensive, etc?  Are these parts I should be salvaging and offering for sale?   I hadn't really considered used brake parts as something to acquire since I'm used to being able to source brake parts for my cars new, but is that not the case for an early pagoda?
thanks
Scott
Scott Allen
'67 250 SL (early)
Altadena, California
seattle_Jerry
« Reply #3 on: May 11, 2011, 15:51:27 »
Well they are available new if you are interested in paying $1200 for a brake drum and $230 per shoe or $920 for the set of shoes,
