Poll
I prefer to buy a pre-cut firewall pad with a close match to the original diamond pattern with:
an approximately 4mm thick foam backing
an approximately 4mm thick jute backing
either one of the suggested backings.
Author Topic: Replica "original' firewall pads  (Read 80148 times)
George Des
Re: Replica "original' firewall pads
« Reply #50 on: May 31, 2011, 19:40:56 »
Dan,
These are not for the fibreboard underdash panels as you have correctly pointed out as still available. The footwells under the carpeting on the interior firewalls are covered in the same material as the exterior firewall pad and there are three other pieces that are up under the dash on the interior firewall.
George
Sableco
« Reply #51 on: June 02, 2011, 07:25:20 »
Hi all
I do agree if the quality is matched and price is reasonable.
I would need 2 sets as well
Basem
Nate
  • Mill Valley, California
« Reply #52 on: June 04, 2011, 17:43:41 »
Count me in for 1.
Arabian Gray / Dark Red Leather
2013 Porsche 911 Carrera 4S Coupe
Black on Black
2013 ML350 4MATIC
Arctic White on Almond Beige
Wife's car that I get to drive
1964 Porsche 356C Coupe
Irish Green on Black
Black Plate CA Car
Unrestored
ricrose
« Reply #53 on: June 04, 2011, 22:56:44 »
Count me in for one also
« Reply #54 on: June 05, 2011, 11:08:17 »
RHD pls
No pressure here Garry. We are not counting on you, oh no...
« Reply #55 on: June 05, 2011, 11:33:48 »
No pressure, much 8)
I have a 70% confidence rating at this point that my upholsterer can match it but I haven't pulled my wrong firewall pad off the car .......yet. I have looked very closely at it to see how easy it is going to be.
Maybe the question ANDY, note, ANDY should have asked is who doesn't need one.
George Des
« Reply #56 on: June 06, 2011, 00:21:18 »
My bet is that if they can do a faithful reproduction and they are reasonably priced, they will sell very well. This is like the ZF 5 Sp of trim items to many of us with these cars.
Drewtee
  • England, Kent, Sevenoaks
« Reply #57 on: June 06, 2011, 08:00:11 »
Hey Garry, I don't mind you taking the pressure on this one  ;)
If you can get this organised through your upholsterer then you are the man  8)
Although,  the pessimist in me says it can't be that easy, can it?!
The great thing is there is the demand to get these reproduced somewhere somehow.
I take it the sample has not arrived as yet?
« Last Edit: June 06, 2011, 09:06:39 by Drewtee »
Andy Tee
Rhd 5 speed 728h with parchment interior
White Californian 280sl LHD
W111 3.5 Cab and Coupe both RHD
« Reply #58 on: June 06, 2011, 09:27:42 »
Hi Andy,
Not arrived yet.  UK to Australia, another world so takes light years.  If it was to do with cricket it would have been here yesterday!
When I get it I have to take it to the upholsterer who is about 200km away so it is all a bit of a slow process.  So long as I keep it moving forward and we have a good idea of numbers so that i can convince him to push on with getting a roll or two it will all be worth it in the end.
They say it might snow here tomorrow, coor blimey, what is the world coming to.
Cheers
« Reply #59 on: June 07, 2011, 03:53:02 »
Hello Garry,
Dependent on looks of the replicas, I am interested in one RHD set for my 250SL automatic.
« Reply #60 on: June 07, 2011, 06:52:31 »
Hi Bob
If he cannot get them pretty close to original then I wont be going there. I saw the Torana XU1 Fire Wall pad compared to the original and it was near replica. Hoping he can do the same for ours.
« Reply #61 on: June 09, 2011, 10:40:46 »
I have received the sample from Andy and also had a talk to the upholsterer.  The sample from Andy is a very old and well worn piece whilst the photos that i have received from several of you show a much more distinct pattern.
Does anyone have a piece from under the dash in the footwell area that is in reasonable condition and possible a better example that I could have.   I only need an inch or two square.
I ask because I am a bit concerned sending this example to Malaysia and they get the wrong idea of how deep the depressions and how distinct they are.
« Last Edit: June 09, 2011, 11:30:25 by Garry »
George Des
« Reply #62 on: June 28, 2011, 22:29:08 »
Garry,
Any more headway on this?
George
49er
  • USA, CA, El Dorado Hills
« Reply #63 on: June 28, 2011, 23:01:26 »
Not sure if this pics will be of any help. Original firewall Pad on my '69SL
John
1969 280SL 003820
« Reply #64 on: June 29, 2011, 01:04:58 »
Update:
I had a meeting on Monday with the Aust Distributor for the material and gave him a set of photos and the sample that Andy had sent me.
He has asked me to bring my car to him (next week) to get an idea of the thickness of the material that is currently being used as the replacement. The bit that Andy sent appears to be bitumen based with a foam backing but was fairly brittle and he indicated that he will probably need a better sample to ensure he replicates it correctly. I am certain that I have seen pads that appear to have coconut fibre on the back side, not foam? And much thicher than 2  - 3 mm that is the current sample thickness.  Has anyone seen that?
Also 1000 meters will probably be the minimum order. So it is critical that the item is correct otherwise someone is going to be left with a lot of material without a  market.
I am hoping that I will be able to get several samples at some point before commitment that I can send to a couple of you to confirm that it is a  match.
This is not going to be a quick outcome but slowly getting there step by step. I am in Perth week after next looking at a Pagoda in bits and hopefully I can get another sample from the interior firewall if it has not all been pulled off.
« Last Edit: June 29, 2011, 01:12:38 by Garry »
bogeyman
  • USA, NE, Omaha
« Reply #65 on: June 29, 2011, 03:16:29 »
Garry:
I have original unmolested material on the interior footwell of my '69.
PM me if you want me to send you a sample.
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
« Reply #66 on: June 29, 2011, 03:29:35 »
Great,
PM sent
  • USA, WI, Mequon
« Reply #67 on: June 29, 2011, 11:52:05 »
The replacement pads I've seen, with the fiber backing are MUCH thicker than the original.
« Reply #68 on: June 29, 2011, 12:07:35 »
...and the originals were dreadful quality.  I do not know what they were made of, but they certainly were one of the least long lasting items on the car.  If an original style and pattern version were made, I would hope it were not the same material.
  • USA, WI, Mequon
« Reply #69 on: June 29, 2011, 12:46:56 »
Did you look at my firewall pictures above?  That's 44 years and 150K miles old!  The material in my interior, floor boards, etc., looks like brand new.  I'd submit that care of the car has more to do with the current condition of the material than the quality of the material.
« Last Edit: June 29, 2011, 12:52:08 by thelews »
« Reply #70 on: June 29, 2011, 13:19:09 »
John,
Is the back of yours the foam or the coconut fibre?  and what is the thickness?
The plan is to get the surface material correctly done in Malaysia and any backing would be added later here in Aust.
  • USA, WI, Mequon
« Reply #71 on: June 29, 2011, 13:34:38 »
John,
I'll look and measure it tonight.  I know the fibre you're talking about and mine is not that and much thinner.  Look at the pics below of the fibre backed replacement and compare to my original several posts above and below.  They lay down entirely differently.
« Last Edit: June 29, 2011, 13:36:37 by thelews »
49er
« Reply #72 on: June 29, 2011, 13:50:10 »
 I would have to agree with John on this.  Considering the extreme conditions in my  engine compartment that this material has to exist in, I think it has held up pretty darn well for the past 43 years ( just celebrated her 43rd anniversay of her build:-) Keeping it clean all those years probably helped. If the repro material holds up half as long, you should be happy.
 No foam backing and barely over .12" thick
John
« Last Edit: June 29, 2011, 14:48:23 by 49er »
1969 280SL 003820
49er
« Reply #73 on: June 29, 2011, 14:52:08 »
I stand corrected, there is a foam backing but the total thickness remains about an .12". The foam has disintegrated around the edges in the engine compartment.
 Haven't had my 2nd cup of coffee yet:-)
John
1969 280SL 003820
bogeyman
  • USA, NE, Omaha
« Reply #74 on: June 29, 2011, 15:17:20 »
Garry:
I just cut out the piece I am sending you and it looks like 49er's - with thin foam backing.
I believe the 230s had a thicker pad originally, but examples I have seen recently are basically in tatters. Apparently they upgraded at some point to the later style.
I think if we can replicate the original color, texture and pattern on the surface with maybe a better under layer would be the best solution.
Rick Bogart
1993 500E
1972 350SL
1995 E320 Cabrio
