Hi everyone,
In preparation for my summer road trip at the end of June, I'm sorting out worn V belts, disintegrated rubber bushing on the alternator mounts, and an oil leak from somewhere at the front of the block.
I've read a number of interesting posts on the forum including ones about the sneaky bolt by the chain tensioner, and this may be my problem but:
The worst of the oil appeared to be around the alternator bracket mounting studs. Are these possible culprits or has oil just accumulated there from leaks higher up?
Also, I have two empty threaded holes on the corner of the block by the alternator bracket. I guess they might be for Aircon mounts. They seem to be blind. Can anyone confirm?
Fourtunately my crank seal seems OK .
Many thanks
Steve.
