Author Topic: driving temperatures  (Read 11941 times)
starparts
Re: driving temperatures
« Reply #25 on: June 04, 2011, 14:29:44 »
I like to thank all contributing to this forum. My stragecy is first replace the fan into a 9 blade fan with visco, if this does not work enough then I will enlarge the radiator, and the last step could be the bypass system. The fan is installed and the last two days I drove with around 21/22 C and the temp stayed on the highway solid on 82 C, stoplights and uphill was maybe 85 C. Till now it worked and will keep a close eye on this.
Cees
bsimaz
« Reply #26 on: June 07, 2011, 13:13:12 »
Mine runs just under the 180 mark.  ~175. [1]
I had to have the radiator re-cored when
fixing the car.
[1]
When it full.  Have a leak starting.   Looks like
it's around the water pump.  Grrrr....
