Author Topic: distributor cap for 1967 230sl  (Read 5624 times)
natenate
« on: May 24, 2011, 08:29:28 »
Hi
I live in south London, Does anyone know where is the best place to get a distributor cap, coil lead, rota arm and a set of plug leads for my 1967 230sl????
Many thanks
Re: distributor cap for 1967 230sl
« Reply #1 on: May 24, 2011, 08:43:46 »
Try EuroCar Parts or GSF (German and Swedish).
You will need to know the Bosch # of the distributor to get the correct cap.
This may help to identify parts:
http://www.sl113.org/wiki/Electrical/Distributor
Naj
natenate
« Reply #2 on: May 25, 2011, 08:06:00 »
Thank you very much Naj
jaymanek
« Reply #3 on: June 09, 2011, 16:01:07 »
Mercedes arent to bad on the price of these parts.. The rotor arm is only £5 from the dealer, the cap is a bit more but still not that bad.
Leads are terrifically expensive from the dealer though! I got mine from Euros.
Euro Car Parts will supply Beru replacement parts which are just as good and around half the price of the main dealer.
Larry & Norma
« Reply #4 on: June 09, 2011, 19:39:14 »
Do you have the Euro Car Part reference numbers?
For cap and ignition lead set?
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
natenate
« Reply #5 on: June 12, 2011, 16:58:50 »
Sorry been away. Dont have the Euro Car Part reference numbers for the cap and leads yet???
« Reply #6 on: June 12, 2011, 21:46:39 »
I always fit genuine MB ignition parts. I've had too many issues using aftermarket parts.
jaymanek
« Reply #7 on: June 13, 2011, 09:37:23 »
This is for a 280SL with the cast iron distributor
Mercedes dealer: Distributor Cap A0001585302, Rotor Arm A0001582031
Euro: Distributor Cap "Beru"  euro no 404110040, Rotor Arm "Beru" euro no 405220050
In all honesty I think the Beru parts are just as good if not better than the dealer supplied Bosch items and the euro car parts cost is around 25% of the dealer!
Euro may supply Bosch items if you ask them too but Beru is OEM and i noticed some items on the car were originally made by Beru anyway.
