Author Topic: rim for 66'  (Read 3619 times)
gatorjaws
rim for 66'
« on: May 25, 2011, 04:52:27 »
Hi , I need a rim for my 66'230sl euro. I don't want to buy the wrong one. Can you folks help me on which measurements I should be looking for? What offset etc?
gatorjaws
Re: rim for 66'
« Reply #1 on: May 25, 2011, 04:54:20 »
Sorry, by rim I guess I mean wheel.
Re: rim for 66'
« Reply #2 on: May 25, 2011, 13:00:36 »
108 400 00 02.
6J x 14 H2 steel rim with three noses which hold the central hub cab.
See:
http://www.sl113.org/wiki/WheelsTires/Rims
gatorjaws
Re: rim for 66'
« Reply #3 on: May 25, 2011, 21:11:33 »
Thank you!
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
Re: rim for 66'
« Reply #4 on: May 26, 2011, 05:55:30 »
Here's a pic of the centre section of one of my wheels. I hope it's clear enough for you to read the stamped digits. The part number seems to be 113-200-0106. I can't find this part number mentioned in the Tech Manual section on wheels and rims. I presume the 113 at least tells me the wheel belongs on a Pagoda! It also says Südrad, which is the mfg mentioned in the TM. So is this a proper wheel?
Peter J
1965 230SL #09474 named Dagny
2018 B250 4matic named Rigel
Re: rim for 66'
« Reply #5 on: May 26, 2011, 15:32:00 »
Quote
113 400 01 06 !
6J x 14 H2 as well; the predecessor of the 108 400 0002.
Looking closely to pj's pic of the dir...  uhem slightly patinated rim clearly proves that number
This is all mentioned in the WIKI.
A look there really helps.
A.
