Author Topic: Windshield Wiper Hardware  (Read 3202 times)
Atazman
  • USA, Ca, Pleasanton
« on: May 25, 2011, 15:38:21 »
Hi guys.....
With the windshield wiper arms, nuts, etc, removed from the wiper posts that extend through the body in the cowl area............ can the posts then be slid down inside the hole under the dash?
I'm stripping the car for painting, and would like to get those wiper posts out of the way.  I have everything loose, but there is still something holding the posts up against the body.  Maybe there is sealant holding them in place??  I don't want to force them down inside the hole until I find out that nothing needs to be removed under the dash.
Thoughts are appreciated.
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
Atazman
Re: Windshield Wiper Hardware
« Reply #1 on: May 27, 2011, 03:12:40 »
To answer my own question.....  The mechanism is held in place with two bolts on the underside of the dash.  The passenger side is accessible by removing the glove box.
Don
67 250 Sl
(#3168) from Italy
DaveB
« Reply #2 on: May 27, 2011, 03:22:54 »
Thanks Don, I was going to check the spare bulkhead/dash in my shed for you yesterday but forgot! You've may have already worked a way to access the driver side but if not I will check. The bulkhead I have is RHD but I guess it will just be  mirror of your LHD.
DaveB
'65 US 230sl 4-speed, DB190
DaveB
« Reply #3 on: May 27, 2011, 12:39:02 »
Looks like you'd have to take one of the dash instruments out, probably the centre gauges, to get at those two driver side bolts.
DaveB
Atazman
« Reply #4 on: May 27, 2011, 19:51:20 »
You are correct, DaveB.  Thanks for your input.
Don
67 250 Sl
(#3168) from Italy
