Author Topic: Vacuum hose missing?  (Read 4239 times)
jaymanek
« on: May 28, 2011, 20:42:02 »
I have a vacuum connection on the intake manifold with nothing going to it and it's not currently blanket off. It's on the opposite side to where the distributor advance goes, so on the right front of the manifold, forward of the Csv.
Any ideas please? I will of course blank it for the time being.
Re: Vacuum hose missing?
« Reply #1 on: May 29, 2011, 10:25:19 »
Hi, Jay,
The port is for the vacuum feed for the vacuum cell on the throttle body.
See ja17's comments in this thread:
http://www.sl113.org/forums/index.php?topic=4500.msg27893#msg27893
Naj
jaymanek
« Reply #2 on: May 29, 2011, 12:21:33 »
Naj mine is a manual, dont think mine has it?
jaymanek
« Reply #3 on: May 31, 2011, 14:45:35 »
well since blanking this point off my car no longer cuts out intermittently at the lights... so quiet happy!
Im convinced this port must be redundant on a manual car?
« Reply #4 on: May 31, 2011, 16:22:29 »
Hi, Jay,
I think you're right.
Could not find anything about the vacuum cell on a manual trans. car.
BTW, does your car have these switches on the gearbox cover?
Naj
« Last Edit: May 31, 2011, 19:04:31 by Naj »
jaymanek
« Reply #5 on: June 01, 2011, 08:55:17 »
Remember I have switched to the 5 speed getrag but the original box doesnt have those switches either... cant think why you would need them!?
On the late US cars with emissions control relays etc., the switches are used to cut off the fuel delivery from the injection pump when the throttle is closed and the car is either in 3rd or 4th gear (clutch engaged).
Naj
jaymanek
« Reply #7 on: June 01, 2011, 09:58:44 »
Whats the point!? clutch engaged, top gears and no throttle? hmmm
Nice bit of knowledge though.
Mine is originally an Italian car.
