Ok. My head has been been stuck under the driver's side of the dash for the past few weeks. I'm sorry, I meant the passenger side. I have... or is it the driver's side? It used...It must be the driver's side? I just spent 2400 miles on and off, driving on that side!? But, there is no more steering wheel and there is still a gas pedal sticking out of the floor on the near side (which is only "near" to me, when I'm on the other side of the car from where the new wiring harness for the speedometer and tachometer illumination is. Otherwise, those folks down under and up yonder call it the far side). Let's just call it the left side for now. I think we can all agree on that!? (except those people that argue: "It depends on which way you're looking at the car". For those people, I only have to say, I suppose you have two left arms too? (depending on which way you look at yourself? ;-)
To be clearer, the small moving space has all of a sudden become a lot bigger!....and a lot messier. I'd say, it looks like a bomb went off in there (don't worry Garry. It's normal....:-)
Things are starting to move over the the right hand side while other things are slowly moving to the left hand side. I keep moving back and forth, sometimes I even get under the car, to remove the LHD rack and pinion steering and to route the main engine harness all through the dash, then through a hole in the most distant corner of the left hand side foot well, then to the engine bay and to various parts in the front that would like to get some power and others that want to send some information back through the hole to the driver. ...Whether he (or she) might be sitting on the left or right hand side of the car.
The reason that this is happening carefully, one step at a time, is that there is no information out there on how the new harnesses should be oriented and routed and it took me a little while to figure out that the center instruments (and all 10 switches- I hope!) all need to swap positions so that the driver in the new off-side (Yes!- right side:-) will be able to get the best view of the most important instruments and switches right away. In hind sight that all makes sense, but when you have an endless Misch-Masch (German technical term) of wires and connector ends all heaped in front of you and running through the dash and between your legs, you don't want to take any chances and disconnect anything until you're sure it is correct. There are still a few loose wire ends that don't readily match up, which is a concern, but I'm sure it will all work out. Recommendations to use the wiring diagram for help were received with a "Thank you very much for that gold nugget ;-), but the wiring diagram for the right hand drive and the left hand drive version is the same one, so.... Studying the old and new wiring harnesses for each wire's color coding and connector and their respective locations in the now slightly larger moving space, was the best way to solve the puzzle. Enjoy the view with these pictures, taken with my trusty LG cell phone/ bore scope :-)....
