Author Topic: screw size for the door pull??  (Read 3838 times)
mcreasy
« on: June 01, 2011, 12:58:35 »
I have a 230sl and I was going over the screws on the door panel  because the previous owner used all types of screws -wood,etc to put together the car. I was trying to get the correct size screws to replace the passenger door handle pull. Does anyone know the correct size. I need 4 of them. Thanks Mary
Re: screw size for the door pull??
« Reply #1 on: June 01, 2011, 14:29:56 »
Hello Mary,
Those are standard metric screws M4 (4 millimeter diameter) with a lens-like Philips head (no countersunk):  (Deutsche Industrienorm) DIN 7985, 4 mm x about 25-30 millimeters long.
The Mercedes parts number(s) is (are) as follows:
007985 004130 Screw
006797 004236 Toothed lock washer
The sad thing is if someone already used self-tapping screws (or woodscrews) before, mostly the screw thread in the door's aluminum frame is already (heavily) damaged and the correct screws with the regular metric thread will not hold nicely anymore ...
Good luck!
mcreasy
« Reply #2 on: June 01, 2011, 22:19:31 »
Thanks so much for the info..I will try and hopefully it will work!
