Mark,
Unless I'm really forgetting something, it is rather straight forward. From memory, the tranmission is sitting on a mount that is bolted through the support plate. Just support the transmission with a jack, unbolt the mount and the dozen or so bolts that hold the plate and remove it. Put the new rubber mount in place as you replace the plate. Tighten it all up. If you have a lift, your beer won't get warm by the time you finish.
