I just changed over the valve cover in my car to a cleaned up one whilst I get what I thought was the original valve cover soda cleaned to put back on, however I noticed that the cover I took off had a screw in type oil filler cap and the one I have put on is the half turn cap with cork seal.
Is the correct one for a Euro 280SL the twist to remove cap? The illustrations in the Valve Adjustment tour in the Tech Manual appear to suggest that.
A second question, I noticed on the rear most cam at the top of the lobe has what appears to be some rusting on it rather than a smooth surface like all the others that suggests to me that the rocker arm is not touching the lobe at the top? Is that indicating a problem?
