Basil,
I have converted four RH drive 280sl's to power steering ,best way is to have a 108 type 280se sedan as a donor everything will bolt on all drillings and threads are already in the manual steer engine,the most awkward part is getting the steering column inner shaft out and having it shortened forty odd mm.apart from that everything is straight forward,you wont be dissapointed with the outcome.
