Author Topic: Can Anyone Identify This Part?  (Read 3610 times)
Jordan
  • Canada, ON, Jordan
« on: June 14, 2011, 01:33:33 »
I am about to replace my distributor, coil, resistor etc.  There is what looks like some sort of condensor wired to one of the coil terminals but I do not know exactly what it is or its function (see picture).  Dan thinks it is some sort of condensor for perhaps radio suppression.  Before I start exchanging parts and perhaps removing this part, can anyone identify what it might be or perhaps someone else has one of these on thier car.  Is it necessary?  It is slightly larger than the condensor on the distributor.  Thanks for any help.
Marcus
Marcus
66 230SL  Euro 4 speed
jaymanek
Re: Can Anyone Identify This Part?
« Reply #1 on: June 14, 2011, 12:56:15 »
standard radio supressor, cost about 99p from a local accessory store!
Work well to reduce interference on radio stations.
Jordan
« Reply #2 on: June 14, 2011, 19:34:31 »
Thanks Jaymanek.  I take it as most others do not have one that it is not really necessary.  I'll remove it and see how the radio sounds.  I can always put it back if there is a lot of interference.
Marcus
clembeauch63712
« Reply #3 on: June 15, 2011, 00:10:15 »
HI; I have one on my 63 and her radio has no anoying static / or ignition clicking at all.. I would leave it on and just temp. disconnect it for Ha Ha 's to see the  difference. your call but maybe nec. if you are running old style copper wires.. let us know how your experiment  works??
          Regards; Clem
