Author Topic: 280SL Engine oil discharge  (Read 4797 times)
bogeyman
  • USA, NE, Omaha
« on: June 17, 2011, 00:25:51 »
I have the opportunity to buy an original engine out of a 280SL.
Owner claims it was running OK but was pushing oil out of the dipstick.
Any ideas what might cause this or what I might look for?
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
Re: 280SL Engine oil discharge
« Reply #1 on: June 18, 2011, 05:18:38 »
The crankcase needs to be vented or this will happen. Good chance the line going from the valve cover to the throttle valve is plugged.
jaymanek
« Reply #2 on: June 18, 2011, 09:27:37 »
Benz Dr is far more experienced than I, but from my experience of modern engines, excess crankcase pressure could indicate bottom end issues.
« Reply #3 on: June 18, 2011, 13:30:17 »
I can't disagree with that but I started with something easy. I've seen some really worn out engines and nothing was coming out of the dip stick. Look for an obsruction first and then do a compression test.
« Reply #4 on: January 30, 2012, 09:23:08 »
I have a similar problem on a 230 Auto that I am going to look at on Wednesday where there appears to be oil venting from the dipstick.  Would the good Dr suggest to check the same problem as the 280 engine in this thread? Meanwhile I will see if I can get a compression check done tomorrow.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #5 on: January 30, 2012, 17:20:22 »
If you have the early 230Sl dip stick with the filter, then it's possible for excess crank case pressure to be vented through the tube. Later engines won't have this filter on the dip stick and all venting is done through the line on top of the valve cover.
Early 230 engines have a smaller port on the throttle body than the later engines probably because all crank case venting is routed through this system. Since the throttle valve is closed at idle, any real pressure build up won't be drawn away quickly enough and you may find that oil is being forced out through seals or cracks in gaskets. If you have that much blow by, it could be pointing to a bigger problem.
« Reply #6 on: January 30, 2012, 21:19:37 »
It is a very early engine I think, I believe the car was a June 1963!
