Author Topic: Injector pump Dip Stick  (Read 4372 times)
Dave
« on: June 17, 2011, 02:31:12 »
Ok, now I am armed with pictures.  I see 2 removable vent caps.  See the pictures.  In the pictures, I removed one cap that looked like where the oil should get filled, but I see no dipstick.  Now, if I have a resevoir that needs filling, how do I see how much oil to put in.  If I have an injector pump that gets oil from the engine, how do I tell.  I appreciate any help.
« Last Edit: June 26, 2011, 09:09:46 by 280SL71 »
Re: Injector pump
« Reply #1 on: June 17, 2011, 08:35:29 »
Hi, Dave,
The dipstick is on the back of the pump and below the solenoid.
Naj
Re: Injector pump
« Reply #2 on: June 18, 2011, 05:15:53 »
If you have the later FI pump it won't have a check valve in the oil line going to the pump or a dip stick on the back cover.
Dave
Re: Injector pump
« Reply #3 on: June 19, 2011, 00:39:14 »
Naj
Your picture did the trick.  Wow.  I never would have found it.  Only cost me a scratched hand.  Success late last night, only getting to the computer now.  Thanks again for taking the time and effort to help me out.
Good news - full of clean fresh oil.
Benz Dr.  Thanks for weighing in, too.
Off to the next thing!
Re: Injector pump
« Reply #4 on: June 26, 2011, 09:02:08 »
How full is full?
On the bottom of the dip stick is a flat side.
The oil level should be no higher than the top mark of flat side.
scoot
  • USA, CA, Altadena
Re: Injector pump Dip Stick
« Reply #5 on: June 26, 2011, 14:39:35 »
Mine has gotten so full that it has run out the top of the red cap filling hole.  That is because I think that gasoline is leaking into the oil area of the pump and is filling up the oil level.  I assume this means a rebuild at some point.  For now I syphon all of the oil/gas out when it goes up and then fill it with oil again.   I've only needed to do that once since the car has been apart for the last year +.
If your oil level is too high, make sure as best you can that it is just oil and not oil/gas.   To remove the oil, a big syringe and some plastic tubing shoved down the fill hole works best.    Or a mityvac would be easier, but I didn't have a mityvac back then...  (mityvac needed for W123 vacuum system)
Scott Allen
'67 250 SL (early)
Altadena, California
