Author Topic: help with upper molding installation  (Read 2593 times)
rmmchl
  • USA, WV, Charleston
« on: June 18, 2011, 02:21:54 »
a lot of my holes are stripped and the screws need to be small enough to go into the countersink, or they affect the vinyl strip that slides into the molding. A pop rivet gun will not go between the small channels on the molding, so that is not an option. some of the holes are 5/32 now-a few are 3/16-------------- some  can be screwed by the 8 x 1/2 flat phillips, that seem to be correct. But I don't know what to do to fasten the stripped out ones. Does anyone have any help on this matter????
michael romeo
1967  250sl
signal red
Larry & Norma
Re: help with upper molding installation
« Reply #1 on: June 18, 2011, 08:11:28 »
I replaced some with stainless steel countersunk machine screws/washers with nyloc nuts, 4mm if I remember correctly.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
