Author Topic: 1971 280 sl Trans issues  (Read 2506 times)
Mark Sean
« on: June 24, 2011, 22:56:31 »
fellow members - replaced the bushings in my automatic shifter - noticeable differance in  crispness of the shifting - however did not solve problem,
 Car only has 1st,2nd and reverse - no 3rd or 4th gears.
fluid level appears red and fine - no smell, 77k miles so i would not think trans would fail..
is it worth it to try and change filter and fluid?
What else could be the issue besides a rebuild?-
any recommendations on a fair repair shop in metro detroit who can rebuild what i have as its the original?
thanks in advance for your input.
Re: 1971 280 sl Trans issues
« Reply #1 on: June 28, 2011, 05:15:23 »
Hello Mark,
The first thing I would do is remove the transmission pan and check it for any debris or broken parts.
I believe the rear pump in the transmission supplies pressure for the higher gears. There was a post here not to long ago. Someone in the group opened up the rear case and fixed their transmission with it still in the car.
Anyone else remember the post?
