9mm 1/4" drive socket with uv joint and extension make the job easier but you still must remove the tach, glove box etc. You might want to get new gauge to dash rubber gaskets, 1 each for speedo tach and center cluster, all new dash bulbs, new scuttlebox drain tubes, lube up the heater cables, the list goes on and on.
