Author Topic: Camshaft, fuel injection, crankshaft timing  (Read 2448 times)
IXLR8
« on: July 05, 2011, 00:04:21 »
Hi--
A few weeks ago, I rotated the engine manually to check the fuel injection plungers for movement and/or to find which plungers might be frozen. All is well with the plungers.
However, when I rotated the engine, I did'nt have a fan belt installed.
Have I messed up the timing between the crankshaft, the cam shaft, and the fuel injection pump?
I believe they are all geared together, but I wanted to double check.
Joe
DaveB
Re: Camshaft, fuel injection, crankshaft timing
« Reply #1 on: July 05, 2011, 03:28:40 »
No problem as the cam and injection pump are controlled by the crankshaft, the fan belt only drives ancillaries like the water pump and alternator (and power steering/aircon).
DaveB
'65 US 230sl 4-speed, DB190
