Author Topic: Distributor Vacuum Line  (Read 4093 times)
ALP
« on: July 19, 2011, 23:36:57 »
Everyone:
I have a 1971 280SL.  Distro is model 0231 185 010.  While spinning the distro body today I manged to snap the original cloth-covered vacuum advance hose.  Since this hose is routed up against and over  hot parts of the engine, I do not want to replace it with common tubing.  Any idea how to source the old style cloth-covered high-temp hose?
Andy
« Last Edit: July 20, 2011, 09:45:27 by 280SL71 »
Re: Distro Vacuum Line
« Reply #1 on: July 20, 2011, 01:34:52 »
I bet that it's the same stuff as the leak off lines used on an older diesel.
« Reply #2 on: July 20, 2011, 03:55:46 »
Most of the line should be hard plastic.  A bt of cloth covered makes the connection.
menesesjesse
  • USA, MD, Indian Head
Re: Distributor Vacuum Line
« Reply #3 on: July 22, 2011, 13:30:48 »
Mercedes classic in california has the hose but not sure if they carry they covering
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
« Reply #4 on: July 22, 2011, 20:25:56 »
My 111 has that cloth covered hose for the fuel venting lines as well as the distributor. I tried the Classic Center a couple of years ago, and all they had is just rubber tubing without the cloth covering. Maybe they have some now but I doubt it.
IXLR8
« Reply #5 on: July 23, 2011, 00:11:22 »
Hi--
Don't forget to look to other sources such as those who sell VW parts.
I replaced all the vaccuum lines and vent lines on my Type 181 VW a few years ago.
Check for parts here:
http://www.thesamba.com/vw/classifieds/detail.php?id=1158506
http://www.thethingshop.com/prodinfo.asp?number=N0203551
http://www.jbugs.com/category/vw-hoses.html
Good luck!!
Joe
« Last Edit: July 23, 2011, 00:19:13 by IXLR8 »
« Reply #6 on: July 25, 2011, 19:38:37 »
Thanks for the lead Joe! That looks like that will work well.
