with our official
Pagoda SL Group logo
from our official partner.
General Discussion
The dreaded linkage adjustment
Topic: The dreaded linkage adjustment (Read 3546 times)
Sphe
May 19, 2004, 11:56:19 »
I believe that the length of my linkages are way way off. If anyone can tell me what the approximate lengths of their linkages are? A picture would be nice so i know what linkages you are talking about, not necessary though.
Full Member
Platinum
Australia, Queensland, Brisbane
Re: The dreaded linkage adjustment
May 19, 2004, 18:54:24 »
Hi Sphe,
George Davis did a good "HOW TO" on linkage adjustments have a look here
http://pagoda113.com/eve/ubb.x?a=tpc&s=3846000021&f=3296041521&m=7246004272
Bob (Brisbane,Australia)
Sphe
Reply #2 on:
May 19, 2004, 19:35:51 »
I did find this page on my own, and it does look very informative. I was just looking for a close-to setting i can put them to, cause I have no idea what the distances should be, and the car is currently not running, so i can't play it by ear.
Full Member
Platinum
Reply #3 on:
May 20, 2004, 03:59:00 »
When you read that document you will see EXACT measurements NEEDED to set up the linkages to get the car running.
If you then follow all the great advice in the article you might actually have the engine running correctly or very close to it.
knirk
Reply #4 on:
May 20, 2004, 04:43:17 »
What the instruction will do is to make sure that when the accelerator pedal is released – the throttle valve is fully closed and the fuel injection pump (IP) is fully closed. The reason for the length adjustment or by using the hole in the bracket, is to make sure the geometry is correct – so you also get full throttle and full deliverance from the IP when the pedal is at the floor. This is a strictly mechanical adjustment which needs to be done before you start playing with the idle air screw and the IP idle mixture screw.
Per G. Birkeland
69 280 sl aut 834
Norway
Last Edit: May 20, 2004, 09:24:40 by knirk
General Discussion
