Author Topic: Upholstery Padding  (Read 4918 times)
IXLR8
Upholstery Padding
« on: July 22, 2011, 00:33:46 »
Hi--
I am planning on using vinyl (Tex) for the dash, the soft top cover, under dash panels, etc.  I have leather for the seats.
Has anyone done their own upholstery in these areas who can give me a tip on padding beneath the Tex?
What type and thickness padding did you use?
I was at the upholstery store today, and the woven headliner material looked intriguing--cloth covered foam about 3/16 " thick.  It looked like it would hold dimension pretty well and not "thin out" when pulled around contours.
Alternatively, the store also had some cloth backed vinyl remnants with about a total thickness of 1/16".
I have also considered closed-cell foam that is used to underlay laminate flooring--it's about 3/16" thick and fairly dense. With it's closed-cell configuration, I figured that I wouldn't have to worry about moisture accretion.
Any experience or suggestions on the above or a better alternative is appreciated.
Thanks in advance for your help.
Joe
Re: Upholstery Padding
« Reply #1 on: July 22, 2011, 05:29:48 »
Joe,
the original foam padding used by MB was called Moltopren which is a polyurethane foam. For the underdash panels it was 5 mm thick (p/n 000 983 01 98 - but NLA)
but thinner (3 - 4 mm) for the dash and soft top compartment lid.
I bought foam sheets from McMaster-Carr,  3/16 thick for the under dash panels and 1/8" thick for the dash and lid. The latter material was also resistant to higher temperatures (>170 degree F).
Don't "pull" the foam around contours, just glue it down lightly.
« Last Edit: July 22, 2011, 05:31:26 by 66andBlue »
IXLR8
« Reply #2 on: July 22, 2011, 15:45:43 »
Thanks, Alfred!
Exactly the information that I needed.
Joe
« Reply #3 on: July 27, 2011, 23:12:33 »
I have just learned that p/n 000 983 01 98 was replaced by p/n 000 983 35 98 9005 which is 10 mm thick and costs about $5/meter from the dealer.
There are also reproduction underdash panels available for $169/set of 3:
http://www.authenticclassics.com/230SL-250-280SL-113Ch-3pc-Underdash-Panel-Set-p/auth-002804-0002.htm
