Author Topic: Hood torsion bar  (Read 2816 times)
Bobo
Hood torsion bar
« on: July 24, 2011, 13:36:26 »
I removed my torsion bar some time ago to repaint the hood. Now I come to refit the hood I am having trouble refitting the torsion bar. I understand that i am going to have problems actually fitting the hood, but my problem is actually fitting the rod into the hood. Am I doing it wrong? Any step by step instructions out there?
Re: Hood torsion bar
« Reply #1 on: July 24, 2011, 15:13:02 »
Use the search function and you can find a lot of material about this, here is one thread (and it contains some further references)
http://sl113.org/forums/index.php?topic=8743
I also tried using "hood tension" as the search string (search all the messages) and there are several more threads to read.
Good luck.
« Last Edit: July 24, 2011, 15:16:47 by Jonny B »
