Author Topic: Brake Lights Out  (Read 2676 times)
Faraizim
Brake Lights Out
« on: July 25, 2011, 19:52:10 »
Hi-
Any expertise would be greatly appreciated. Any advice for a 1970 (later style tail lights). All tail lights work, except both brake lights.
Many thanks
Re: Brake Lights Out
« Reply #1 on: August 03, 2011, 01:03:14 »
The brake lights get power from fuse no 5.  The turn signals also get power from this fuse so I assume the fuse is good since you say the turn signals work.  This would indicate a problem with the brake light switch.  If you follow the brake pedal arm up under the dash board you should find a switch that closes when the brake pedal is depressed.  I'd start there and see if the switch is broken and not coming in contact with the brake pedal.
