Author Topic: Help with fuel injector wrench source  (Read 9092 times)
69280sl
  • USA, IL, Elk Grove
« on: August 03, 2011, 01:42:44 »
I have absolutely no luck with the search function. Hope someone with better search skills or memory can help.
Sometime earlier this year someone posted a link to a source for an offset 19mm end wrench (I think it was 12 pt) that could be used to loosen or keep the injectors in place while loosening the lines. Then it turned out these were available from a number of sources. Of which I can find none.
Can anyone help.
Gus
Gus
sandcrab59
  • USA, MA, Lunenburg
Re: Help with fuel injector wrench source
« Reply #1 on: August 03, 2011, 21:01:18 »
Hi Gus:
Are you the Gus that was at Blacklick last weekend.
If you were I was the windscreen purchaser.
Here is where I purchase my tools from since 1972.
describe what you are looking for and check all 3, they will have it.
A-Assenmacher Specialty Tools
 Boulder Co
800-525-2943
B-Baum Tools Unlimited
 Sarasota, FLA
800-848-6657
C- Metric Automotive Tools
Ask for Mike
800-622-6867
Canoga Park CA
Tell all three that Tom Mrowka of North Country Foreign Imports (Mass)
Said to call.
Ask for there catalogs ,you should see there catalogs for Mercedes Benz Tools.
Let me know how you make out.
Send reply to my profile email address because I will probably never find where I am right now.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
69280sl
« Reply #2 on: August 03, 2011, 21:45:35 »
Yes, that was me. Hope you are now enjoying quiet conversations and unruffled hair in your top down rides.
I appreciate your reply, but I'm still hoping for the link. That way I can click to buy. No phone calls, no descriptions.
Thanks much
Gus
Gus
merrill
« Reply #3 on: August 04, 2011, 02:41:20 »
you can also try
http://samstagsales.com/
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #4 on: August 04, 2011, 12:33:42 »
Gus, I KNOW you know how to do this...
http://www.asttool.com  Assenmacher
http://www.baumtools.com  Baum
http://mercedesengines.net/  Metric
That last link isn't a "tool store" but our friendly "Metric Motors" rebuilder.  That's what Tom Mrowka spoke of however.  If you don't want to speak with anyone you can easily be put on the path to finding the wrong thing at the wrong price, particularly for something a bit obscure.  Tom's suggestion was good: call them.  At least, you have links to send emails too...
http://www.asttool.com/detail_page.php?from_search=y&tool_number=H%204550&total=55&offset=36&stype=bymanf&manf=Mercedes  Is it possible this is the tool you are looking for?
Baum has it listed, and Samstag is a big Hazet dealer as well...
« Last Edit: August 04, 2011, 12:52:10 by mdsalemi »
69280sl
« Reply #6 on: August 04, 2011, 17:13:07 »
Thanks all, but still no joy. I need a 19mm wrench for the injectors. I had a situation where the fuel line fitting would not loosen, but the injector started to turn and continuing would have twisted the line.. This wrench would keep the injector from turning while additional torque is applied to the line fitting.
This is resolved now, but I want to be prepared for next time.
This was like a flarenut wrench but with one face extended to reach down and wrap around the injector.
Again, thanks
Gus
Gus
« Reply #7 on: August 04, 2011, 19:03:58 »
Well, if and when you find it let us know...
« Reply #8 on: August 05, 2011, 00:57:59 »
... This was like a flarenut wrench but with one face extended to reach down and wrap around the injector...
Hi Gus,
you sure have an expensive taste!  ;)  That "wrench" will only set you back by $94.  :o
Available from http://www.samstagsales.com - search for "Elora 775L-19".
If you just want to prevent the injector from turning while you remove the fuel line I think a cheaper 19mm crowfoot should work too.
Samstag will sell you one made by Stahlwille (540-19) for $56,
or you can buy one from Snap-on for $20:
http://buy1.snapon.com/catalog/item.asp?item_ID=2185&group_ID=266
glenn
« Reply #9 on: August 05, 2011, 01:51:46 »
Tom, What is 'North Country Foreign Imports'?
Hi Gus:
 Boulder Co
800-525-2943
 Sarasota, FLA
800-848-6657
Ask for Mike
800-622-6867
Canoga Park CA
Said to call.
