Author Topic: cushion on outside of fuel tank filler.  (Read 2763 times)
Troup
« on: August 12, 2011, 17:28:49 »
This cushion goes around the filler neck and snugs up against the back of the rear panel where the neck comes out of the sheet metal.
Where can I find out what this material is made of or where can I find a replacement?
It appears to be foam that has been applied from an expanding can, like some insulation material.
Any info would be appreciated. thanks
Re: cushion on outside of fuel tank filler.
« Reply #1 on: August 12, 2011, 20:17:50 »
You should be able to source this from the usual suspects, K&K, Millers, Buds Benz. I replaced mine some years back and it was actually fairly easy.
Gas filler neck grommet - $32 at Millers. K&K does not show one, Buds has one shown, but no price.
IXLR8
« Reply #2 on: August 12, 2011, 21:59:59 »
This is actually a collapsible gasket that seals the floor of the trunk from the outside by squeezing it between the trunk floor and the top of the gas tank.
I got mine at K&K, but I think an enterprising chap could make one out of closed cell foam.
Joe
