Author Topic: PS pump end play  (Read 3461 times)
twistedtree
  • USA, VT
PS pump end play
« on: August 13, 2011, 22:07:07 »
I'm working through a pile of issues trying to get this car running, and one thing I noticed is a lot of end play on the PS pump.  The pulley appears to be attached and tight, and as best I can tell the end play is in the shaft itself.  I haven't measured it, but I'd say it is a couple mm.
Is this normal?
I've also got PS fluid spitting up around the reservoir cover nut when shutting off the engine which I gather is indicative of air in the system.  Perhaps the air is related to the end play?
Power Steering
« Last Edit: August 16, 2011, 09:06:43 by 280SL71 »
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
Re: PS pump end play
« Reply #1 on: August 16, 2011, 00:40:53 »
Can't say for sure but a small amount of end play seems reasonable.  I would be more concerned about and noise, radial bearing play and and shaft seal leaks.
