Thanks Benz Dr. That is what I'll do. Why fix it if it aint broke should be my motto.
I'm looking forward to fitting my ZF transmission at some future date but currently it is in the UK and I'm in Australia. I foresee some difficulty sourcing the linkages and transmission mount. I thought these may return to production now that the new run of ZF transmissions has been confirmed, but I don't know if that's the case. Hopefully some aftermarket manufacturer will step up and provide them.
A bigger potential problem is the fit of the trans in the tunnel. According to the Meredith book there was a change in the tunnel to accomodate the trans sometime in '66. I don't know whether that means the trans cannot fit pre-'66 cars (without surgery), or whether it's just less convenient to do so. The Meredith book lists the ZF as an option from late '65 but I'm unsure whether this means the trans was fitted to late '65 cars, prior to the tunnel change, or whether it could be ordered in late '65, with delivery in '66, post tunnel change. What's the build date of your car?
Yes Gatorjaws please let us know how the new kit performs. The pressure plate in that kit IS a diaphragm style right?
