Author Topic: Nyalic coating  (Read 5543 times)
69280sl
  • USA, IL, Elk Grove
Nyalic coating
« on: September 03, 2011, 03:26:06 »
Looking thru some old Yahoo content, I see Frank Mallory Sr. recommending this for clearcoating various parts. I was thinking of using it on the band clamps holding the coolant overflow tank. Further searches show it is used a lot in marine and aircraft applications. It sounds like a very good product.
The "hits" show a lot of Australian, New Zealand posters, but no sources for Nyalic.
Anyone know where to get it?
Gus
Re: Nyalic coating
« Reply #1 on: September 03, 2011, 04:24:17 »
Hi Gus,
when I was more hooked into sailing I remember that many boat owners used this stuff to treat hulls since it was cheaper than varnish and easier to apply.
The source was:  http://www.nyalic.com/about.html
It is sold in a spray can but very expensive: http://www.italiancarparts.com/paints_coatings/Paints-Coatings.html
The problem with Nyalic is its low resistance to solvents and I am not sure how it would hold up in an engine bay.
For this reason I have used VHT SP115 satin clear coat on the manifolds and other parts in my 230SL and Joe A. has now also used it on the 280SL.
http://www.vhtpaint.com/products/flameproof/
More here: http://www.caswellplating.com/vht/vhtclear.htm. You can also buy it from Amazon.com.
On  car it can be cured simply by firing up the engine to the desired temperature. Since the manifolds were off the car I used a gas grill to cure them as instructed.
« Last Edit: September 03, 2011, 04:32:08 by 66andBlue »
Re: Nyalic coating
« Reply #2 on: September 03, 2011, 09:54:21 »
I was did a cosmetic clean up of a 1966 Mustang some years ago. A lot of Mustang parts will rust overnight once the old oil and grease is cleaned off.
I used Nayalic to protect the newly cleaned parts.
The Nayalic was from Eastwood.
Richard M, NYC
69280sl
Re: Nyalic coating
« Reply #3 on: September 03, 2011, 14:55:44 »
Thanks, Alfred and Richard.
Gus
