Author Topic: The Pagoda SL113 Group Firewall Pad Recreation Project  (Read 135196 times)
mait
  • Canada, MB, East St Paul
Re: The Pagoda SL113 Group Firewall Pad Recreation Project
« Reply #150 on: November 13, 2011, 19:20:20 »
Please put my name down for the second production run. I need one set for a LHD 63 230sl.
Thx - Mait
m8 - 63 230sl
« Reply #151 on: November 14, 2011, 02:32:59 »
Hello Mait and Tom,
I have put you on the list for the second production run in addition to all of those who were on the list for the current batch.
We had a few pads that had flaws and that cut the supply short.
So here is what I have:
1. Mait 1x
2. Tom 2x
3. Orion 1x
4. jetblack123 1x
5. RTenges 2x
6. David Williams 1x
7. mdsalemi
8. atlanta230sl 2x
9. labella 2x
10. holden66 1x
11. smiledoc 1x
12. quattrouser 2x
13. atlanta230sl
14. ctm14 2x
15. menesesjesse 1x
16. Gerry 1x
17. Bob G 1x
Who is missing?
« Last Edit: November 17, 2011, 18:19:24 by 66andBlue »
menesesjesse
  • USA, MD, Indian Head
« Reply #152 on: November 14, 2011, 05:18:24 »
I would like 1 LHD pad for my 65 230SL
Jesse
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
Gerry
« Reply #153 on: November 15, 2011, 02:44:20 »
I would like to order a LHD set for my 1969 280 SL , without the vin # cut out . Thanks for all hard work that all of you involved in this project have done!
Best regards, Gerry
Firewall pad - color changes?
« Reply #154 on: November 16, 2011, 06:33:53 »
Some of you who have received the pads asked me about the brownish surface hue and whether this was original so I decided to answer here in case more are interested in what we have found out.
Of course, everybody who as ever seen a good firewall pad knows that it is black and a bit shiny and the many photos that were posted in this topic and the one before by 49er and thelews, and many others demonstrate that quite well. Clearly, our material is not pitch black and not shiny, but then it also wasn't exposed to a hot engine compartment and oil fumes for 45 years either. Obviously we do not know what the color of the very first material was but we do know what the color was of a pad that was bought in 1974, and even better, we know how this color has changed after installation.
The owner of a 250SL bought two pads in 1974 and installed one in his car but saved the other one since he knew that the material has a limited life time. Dave Gallon, who is currently restoring the car, removed the pad again and guess what, it is now black but the other one is a medium gray as shown in the attached photos.  The owner believes that the gray one hasn't changed color over the years since he had unwrapped it a few times to be used as a template to cut bulk material and believes that he would have noticed.
I have taken these photos in the shade and in full sunshine and on two different backgrounds, hoping that this will provide a good impression for how the surface color has changed over the last 27 years.
So, here we have a pad that was and still is gray - but not brownish - and that turned black after installation. We do not know if our material will turn black over time but given this example we think it might change too.
Since we are all used to seeing a black firewall pad and some may not want to wait an obvious solution is a color change. Because I can only attach four photos I'll show the options in my next post.
« Reply #155 on: November 16, 2011, 06:59:19 »
Here are some ideas and photos showing how one can change the color of the pads to reflect more what we are used to seeing in cars.
The simplest is to use black shoe polish, it is cheap, works well and gives you an idea what the pad will look like. It is also somewhat reversible because the color is NOT water proof and will wash out again.
A more permanent solution is to use a vinyl dye and one has the choice between matte and gloss.  I have use Dupli-Color HVP 104 (gloss) and HVP 106 (matte) and have shown the results to Brian Peters at Motoringinvestments.  He prefers it glossy and and as thick a layer as possible to simulate old pads. My preference is more a thin layer and matte. Fortunately, the first coat of even the glossy paint will be matte because it is absorbed rapidly by the fabric and one needs to add several thin layers to achieve a gloss and for this reason one can stop at any time once the desired sheen is achieved.
But be careful if you do this, apply very thin coats only! This spray paint can be a bit uneven and one should never return a stroke above the material but only outside since the return point will get more paint and it shows. The good part is that once it has dried for several days it can be oversprayed with an acrylic dye, for example, Dupli-Color DA1603 to even out the appearance.
Her are the photos, you be the judge.
450sl
« Reply #156 on: November 16, 2011, 18:47:53 »
Hi Alfred,  Could you please give us a reminder here by the time the Firewall Pads are available in Europe ? thanks Marco
hkollan
  • Spain, Castilla-La Mancha
« Reply #157 on: November 17, 2011, 06:33:37 »
Hi Alfred,
After volunteering to wait for the second batch, i sent you a PM confirming that I would take three pads one for each of my pagodas if possible.
If you could add that to your list of orders I would be happy, since I seem to be missing from your list in your postimg on the 14th of nov.
Regards
Hans
Hans K, Cuenca, Spain
Gerry
« Reply #158 on: November 17, 2011, 16:14:40 »
Hi Alfred; I forgot to ask when I placed my order if you have an idea of when the second run for LHD pads will take place ?  Thanks, Gerry
« Reply #159 on: November 17, 2011, 17:24:23 »
Some I meet has already done the pebble finished fire wall pad. I do not care for it  and would like to place an order for
my USA 1968 280SL LHD. I am sure ours will be better. Please let me know when it is complete and if you can send me price and pictures of the  final product.
8 years ago I put the after market pad on my car. works well was cut nicely. But I plan to repaint the car and have some body work done, it will not be a show car but a nice driver and club display car.
« Reply #160 on: November 17, 2011, 18:18:14 »
.... Please let me know when it is complete and if you can send me price and pictures of the  final product. ...
price and photos and instructions are right here in this thread. $125 + shipping, just read the details.
Thanks.
« Last Edit: November 18, 2011, 03:39:11 by 66andBlue »
BABAK
  • USA, CA, Valencia
« Reply #161 on: November 21, 2011, 00:29:39 »
You suggesting shoe polish.
How original is that?
69 280sl dark olive automatic
71 280sl bronze brown
70 280se coupe light Ivory
59 190sl
61 190sl
www.vintageeuroparts.com
SilverSpear
  • Abu Dhabi, UAE
« Reply #162 on: November 25, 2011, 08:33:55 »
1. Mait 1x
2. Tom 2x
3. Orion 1x
4. jetblack123 1x
5. RTenges 2x
7. mdsalemi
8. atlanta230sl 2x
9. labella 2x
10. holden66 1x
11. smiledoc 1x
12. quattrouser 2x
13. atlanta230sl
14. ctm14 2x
15. menesesjesse 1x
16. Gerry 1x
17. Bob G 1x
18. SilverSpear 1x (Euro LHD with firewall plate)
Euro 2013 Mercedes 350SL
DaveB
« Reply #163 on: November 26, 2011, 22:45:31 »
Here's a photo from the April 1965 edition of Australian Sports Car World showing the firewall pad disintegrating on an almost brand new 230sl. No hope of an original 230sl pad surviving.
DaveB
'65 US 230sl 4-speed, DB190
450sl
« Reply #164 on: November 27, 2011, 18:55:42 »
Recieved the Pad : thanks Guys good job !
circle
« Reply #165 on: November 28, 2011, 16:57:08 »
I would like 1 LHD pad for my 66 230SL
Regards
Circle
ghenne
  • Canada, ON, Toronto
« Reply #166 on: November 28, 2011, 19:30:53 »
Got mine today - they look good. Thanks to David Gallon and Alfred for making this happen!
jaymanek
« Reply #167 on: November 29, 2011, 20:01:07 »
I'm sure I posted here the other day but my message has vanished!
I woul like a RHD pad for my manual car. Engine bay pad only. How and where do I pay. Thanks
« Reply #168 on: November 29, 2011, 20:39:03 »
Jaymanek,
Have added you to the UK list.
 In due course when the pads are cut, packaged in bulk to UK and are ready for distribution, you will be contacted and given a Paypal invoice for payment and seek a shipping address.
« Last Edit: November 30, 2011, 10:09:17 by Garry »
johnwallis
« Reply #169 on: December 07, 2011, 23:08:23 »
Hi Alfred,
Can I please be added to the RHD UK list for 1 firewall pad set for my 250 SL please.
Thank you and everybody for all your hard work,
John
« Reply #170 on: December 08, 2011, 02:33:00 »
John, you are in!  ;)
johnwallis
« Reply #171 on: December 08, 2011, 12:10:56 »
Great news thanks, I have had an email from Naj who is willing to accept the firewall pad with the others he has ordered, so if its OK please send to to him
John :)
jkosal
« Reply #172 on: December 09, 2011, 22:54:55 »
I would like one LHD set for a 65' 230SL.  I am assuming it is not too late to get my name in for the second run of pads.  I have a paypal acoount.  However, I am confused how I go about purchasing this item?  Is this process cover in a previous reply?  Thanks for the assistance
MBparagon
« Reply #173 on: December 12, 2011, 06:53:59 »
Hi Alfred :
I also would like to order one set for my 66 LHD 230sl if it is not too late for the 2nd run.  Thanks
Eng
w113NY
« Reply #174 on: December 12, 2011, 21:13:29 »
hi there, could you please add me to the list? i would like to purchase two of the pads for my 71 280 SL. one for now and one for "down the road" . I would be very happy with one if supply is limited. cheers, christian
