with our official
Pagoda SL Group logo
from our official partner.
Oil line?
Topic: Oil line? (Read 5055 times)
Joe
Full Member
Silver
USA, CO, Colorado Springs
Oil line?
October 02, 2011, 17:20:09 »
I found what is apparently an oil line that is connected on one end and hanging on the other. The line is connected to a banjo fitting just behind the crank pulley at about the one o'clock position. Where does the other end of this line fit?
Joe
1965 230SL
Associate Member
Platinum
United Kingdom, Surrey, New Malden
Re: Oil line?
October 02, 2011, 17:43:18 »
Hi, Joe,
If you mean this one, it goes to the back of the F I Pump.
Naj
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Oil line?
Reply #2 on:
October 02, 2011, 18:32:51 »
I think that woud be the line that goes into the trunk to vent the over flow tank on the fuel tank.
Fumes from the fuel tank are vented directly into the engine where they are drawn into the manifold through the vent line and hose going to the throttle valve.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Joe
Full Member
Silver
Re: Oil line?
Reply #3 on:
October 02, 2011, 21:14:38 »
To clarify, the banjo bolt is on the front of the block, just behind the crank pulley. The pipe is black metal and there is a short bit of rubber hose attached to the open end with a clamp. This obviously is meant to attach to another metal pipe (somewhere).
I also should have mentioned that the engine is a 280SL engine.
Joe
Last Edit: October 02, 2011, 23:27:41 by Joe
Full Member
Platinum
Australia, Victoria, Kyneton and Brisbane Queensland
Audit Committee
Re: Oil line?
Reply #4 on:
October 02, 2011, 23:59:16 »
Is your power steering working, its not the oil line from the bottom of the power steering reservoir?
SLS Power steering breakdown diagram, item 46, steering
http://www.sls-hh-shop.de/index.php/language/en/cat/c3_Mercedes-Benz-230SL-250SL-280SL-Pagoda--R113-W113-.html#cat_113_position_60_prod_0
Last Edit: October 03, 2011, 05:28:22 by Garry
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Associate Member
Platinum
Re: Oil line?
Reply #5 on:
October 03, 2011, 05:21:30 »
Nooooo! It's the fuel tank venting line on a late 280SL.
1970 3.5 Coupe
1961 190SL
1981 300SD
2013 GMC Sierra
1965 230SL
Joe
Full Member
Silver
Re: Oil line?
Reply #6 on:
October 03, 2011, 13:04:13 »
That makes sense, Dr. So when a 280 engine was put into the 230 by a DPO, it was just left hanging, venting to air. That would explain the absense of a place to attach the loose end.
Now, what, if anything, should I do about it?
Joe
Associate Member
Platinum
Re: Oil line?
Reply #7 on:
October 03, 2011, 15:16:11 »
You can plug it or remove the fitting at the front of the block and get a screw in cap that's used in that application.
1970 3.5 Coupe
1961 190SL
1981 300SD
2013 GMC Sierra
1965 230SL
Oil line?
