Author Topic: Rear Axle Inner and Outer seal parts numbers  (Read 2871 times)
Paul Robinson
« on: October 12, 2011, 12:33:12 »
http://www.sl113.org/wiki/DriveShaft/RearWheelBearings
This diagram from the website is showing both seals as having the same parts number 0019974746.  Is this correct?  Looking at the split rear end on my garage floor, the seals look to be of different sizes with the outer seal having a larger internal diameter than the inner seal.  From my parts search at the Mercedes parts website (http://epc.startekinfo.com) I show the inner seal to be 0019973446, and the outer seal to be 0019974746.  So is the Pagoda Technical Manual correct, or should I believe my own lyin' eyes?  Thanks for your time,
Paul
Re: Rear Axle Inner and Outer seal parts numbers
« Reply #1 on: October 12, 2011, 13:18:46 »
Hi, Paul,
The Tech Manual is incorrect.
The part #s you have worked out from the EPC are right.
Naj
Paul Robinson
« Reply #2 on: October 12, 2011, 15:44:20 »
Thank you, Naj.
Paul
