Author Topic: Steering wheel,less hub pad  (Read 3190 times)
major
  • Denmark, Ringkobing, Struer
« on: October 19, 2011, 05:57:51 »
Hello, Denmark calling.
Can anyone help me, I wan`t to buy a new steering wheel and it`s so expensive, that I want to be sure of the model mounted in my car.
ID.No. 042-012032 indicate that it`s item no. A112460003, but I am  not sure of the model in the car is an item no. A1124600203 or A1124600003.
Can anyone tell me the difference.
Thank you for Your help
Sorry, forget it, I have found the ansver in the technical manual, late wheel 0203 has two grooves in front and 4 small holes in the rear.
« Last Edit: October 19, 2011, 12:30:10 by major »
Re: Steering wheel,less hub pad
« Reply #1 on: October 19, 2011, 16:37:49 »
Part number 112 460 02 03 is a dark graphite grey steering wheel and was installed in cars starting with chassis number 010275.
Part number 112 460 05 03 is an ivory colored steering wheel installed in cars starting with chassis number 010611.
Do you need a black or ivory colored wheel?
