With reference to the induction micro-switch, what is the correct procedure to adjust it correctly ?
Eric,
Have a look at this thread about the throttle switch where I explained how to adjust it:
http://www.sl113.org/forums/index.php?topic=13583.0Isn't the back emf only produced in a coil / winding and not a switch?
That is correct.
The arcing you see across the switch is the physical manifestation of the back EMF produced by the coil when the magnetic field in the coil collapses.
Am I correct in thinking the spark at the sparkplugs occur when the points open?
If this is true then you need the back emf created by the collapsing field to
induce the HT. This is a case where the back emf is desirable and so should
not be destroyed with a diode...
That is also correct.
When the ignition points open, it results in the magnetic field in the primary winding of the ignition coil to collapse.
It is the collapse of this magnetic field that induces current in the secondary winding of the ignition coil.
The ignition coil is nothing more than a transformer, meaning the secondary winding has more turns of wire around the core than the primary winding.
In short, more turns in the secondary = higher induced voltage when the magnetic field in the primary winding collapses.
Unfortunately some arcing across the points would occur due to some back EMF being generated, but that is taken care of by the condensor. Some of the energy stored in the condensor when the points open is fed back into the primary winding when the points close again to build up the magnetic field in the primary.
In theory it could work as most electronic circuits that employ a power transistor/MOSFET to switch inductive loads have a
fly back diode mounted across the current carrying path protect said transistor/MOSFET.
