I had such good luck with the CSS diode (thanks Larry
, I am hoping to install diodes at the terminal block for both the idle switch and the kick down switch but ran into some questions. As I said, I am not an electronics expert! In order to find the +, I did some tests and below is what I found:
With wires disconnected at the idle and kickdown switches and ignition on, I found 12 V at the wires feeding both switches.
1st question. According to the trans diagram, it shows these two switches to have feed wires hooked to the ground. Therefore they would be switching the ground just like the pressure switches do. Am I reading that correctly? But my switches clearly have +12V feeding them. I need help understanding that.
With the wires feeding the trans terminal block disconnected and with the ignition on, I found:
- The small terminal had 12V at kickdown and 0V at 1/2 throttle and at idle.
- The medium terminal had 12v at idle and 0V at 1/2 throttle and at kickdown.
- The large terminal never had 12V and was always grounded with the ignition on.
So to me, the two HOT (12V) terminals are the small (kickdown) and medium (idle) and the large is the ground.
2nd question. Larry has both bands of the diodes facing the medium (idle 12V) terminal. In my case, seems like you would want one diode band facing the medium (idle) and one facing the small (kickdown) terminals. Then both diode leads opposite the bands would be installed to the large terminal. Is that in anyway correct?
Maybe my W111 is wired differently than the 113 because the diagram just doesn't make sense to me. And I need help understanding why Larry installed the diodes the way he did.
Thanks for the help!!!!!
