Author Topic: spring for convertible top  (Read 4058 times)
tradjim
« on: October 28, 2011, 00:56:56 »
My spring snapped part # 77-3321 ..the problem is the bracket that it attaches to also snapped - I ordered a new spring but i guess the other piece has to be weilded .My question is what is the purpose of the spring'-my top now is much easier to put up - thanks
« Last Edit: October 29, 2011, 09:18:21 by 280SL71 »
tradjim
Re: spring for convertable top
« Reply #1 on: October 28, 2011, 22:45:59 »
I guess this is a first
dtuttle123
« Reply #2 on: October 28, 2011, 23:31:26 »
Nope.  It's not an uncommon problem.  I have a similar situation in my 250SL.  I don't know if you can weld the bracket, or better to replace.  Replacing is a big deal from what I understand.  The purpose of the spring is to make the raising of the top easier.   I put my top up/down maybe 3 times a year, and it's not an issue without the spring.   I would just live with it.
tradjim
« Reply #3 on: October 29, 2011, 00:52:46 »
Thanks - doesnt seem like a big deal - and the top is much easier to put up without it
shanghaitom
Re: spring for convertible top
« Reply #4 on: November 03, 2011, 00:15:22 »
the purpose of the bow retention spring is to make putting the top up and down a bit easier (the rear piece anyway).  I have a 250 and 280SL with the bracket broken on both.  I have had a replacement piece welding on one, but had to fabricate the broken piece.  It works well, but is not necessary.  I have pictures somewhere if helpful.
jeblack123
  • USA, GA, Albany
« Reply #5 on: November 03, 2011, 01:42:08 »
Same problem here. Would it be possible for you to post the picture of your repair? Thanks.
Eddie
