Update:
I did some servicing to the Pagoda last Saturday after this long trip across the US. Checked the brake pads which are still good to go for a while, did all the greasing, checked oil level in the transmission and rear end. I replaced some shims on top of the right bank valves by slightly thicker ones as this engine always had a bit of ticking since I fitted the euro camshafts. The engine is now quiet as it should.
While I was there, I also replaced the front suspension spring top rubber shims by thicker ones and I feel the car is now sitting as it should in the front.
I have also decided to replace the mechanical fan by an electric one, the reason being that I couldn't reuse the Pagoda shroud after my transplant. As a result the engine temperature had a tendency to increase a bit in slow traffic during the heat wave. In addition the visco coupler I have seems not to disengage properly at higher rpm inducing a lot of propeller noise as long as the coupler is engaged. So I ordered a 16" electric fan as well as a variable control unit which will engage the fan at 60% above a certain temperature threshold and increase up to 100% depending on coolant temperature. It will also keep the fan running for 30 seconds after the engine is shut off. I will install it as soon as I receive it and see if it solves my issue. If not, I will have the radiator recored with an upgraded core (which I did on my Coupe with great results).
I have also ordered a Retrosound radio, two 4" single voice speakers that will replace the stock ones in the black plastic casings in the foot wells, and an oval dual voice speaker (that accommodates stereo) to put on top of the dash under the wooden grill. I could have had my original radio rebuilt, but I did this on my Coupe and it didn't last very long. So this car not being original anymore, I thought that upgrading to modern technology with RDS and ipod input for a very reasonable price was the way to go.
I'm also waiting for a case of 20w50 Bad Penn oil which is said to have the required amount of zddp for the camshafts.
I checked all the rest on the car and all is good. This car is quite easy to maintain including washing it. It is so small that washing it takes about half the time it takes me to wash my Coupe!
